TwinTurbo.NET: Nissan 300ZX forum - check ecu for codes. might be a loose connection. look for
Subject check ecu for codes. might be a loose connection. look for
Posted by Krazyd27(Houston) on January 22, 2013 at 12:31 PM
  This message has been viewed 216 times.
In Reply To Possible engine failure....any thoughts...? posted by jmt-z on January 22, 2013 at 11:41 AM
Message Corrosion around cas, ptu, coolant temp sensors. If you do get it to start perform a power balance test by renoving spark from each cylinder via unplugging coil pack to make sure each cylinder is firing. Best of luck
